SLBB
Jan 02, 2020Follower
Cant open apps on my LG smart tv after new router installed
I can not open any apps on my smart tv after connecting to wifi orbi RBK22. my TV shows connected but no apps will open
Feb 27, 2020Guru - Experienced User
Any progress on this?
SLBB wrote:I can not open any apps on my smart tv after connecting to wifi orbi RBK22. my TV shows connected but no apps will open
Drfamulac
Feb 28, 2020Aspirant
This same thing happened to me and It was because the orbi was on router mode, not access point mode. Once I switched to access point mode, all works great. I had my original Verizon router in the basement doing the routing. I did the orbi auto set up and just assumed it would detect and make the orbi an access point. It didn’t, and I ended up with two routers on the network which isn’t good. Switch the orbi to access point (AP) mode and it will fix the issue.
- FURRYe38Feb 28, 2020Guru - Experienced User
For future reference.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
