cashpoor
Jan 14, 2020Aspirant
Can't perform update if Orbi RBR20 is offline
Hello all, Hope someone can help me here. My Orbi is offline and I'm unable to perform a firmware update from my I phone. Tried to perform it through my PC to no avail. Thanks, Adam
Jan 15, 2020Guru - Experienced User
What browser are you using?
cashpoor wrote:Hello all,
Thanks, Adam
- cashpoorJan 15, 2020Aspirant
I'm using an Arris NVG 589 router and FireFox is my browser though as of now I'm going to try and use IE to try and perform the update manually.
At the bottom of my I phone screen it says Version 2.4.12.5 on the Orbi app.
- FURRYe38Jan 15, 2020Guru - Experienced User
Your modem has a built in router already I believe.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option #3...
