Augustus_377
Dec 26, 2018Guide
Can't Port Forward or Host Game Servers with Orbi
Hi, i've been searching around online for quite a while now and se a lot of people have had problems with port forwarding on orbi systems. But i haven't seen an article or forum post like with mine. ...
- Jan 02, 2019
Ok. Take your time when doing it and start with the Orbi router first. Turn off the satellites and don't worry about them until you have the Orbi router setup and tested. Ensure the configuration of the ISP modem is correct for your gaming needs. The Orbi in AP mode will only just pass thru data from the modem to your PC. It won't effect what you have set up on the modem/router while in AP mode.
Augustus_377
Jan 01, 2019Guide
Nope.
Frontier makes you pay to even ask them if bridge mode is possible. And that is not an option for me. Ugh, why does NETGEAR have to be so complicated. We got extenders when we first moved here and they just stopped working. Now this, it's just dissapointing.
Jan 01, 2019Guru - Experienced User
IF the Orbi in in AP mode, configuration of the ISP Modem and router for gaming and such is all thats needed. Would not have to do anything with the Orbi.
- Augustus_377Jan 01, 2019Guide
That's what I thought but putting the Orbis in AP mode made no difference. I still couldn't host servers or do anything different. When I was on my ISP's Router, hosting servers was fine and everything else. If the Orbis are in AP mode do they still make a NAT?
I have talked to NETGEAR support at least 6 times and all they've said is contact my ISP which is ridiculous. They should be able to help me fix my product. One agent said they'd contact a "Higher Team" and send me an email 12 hours later. And three days later I haven't heard anything since. If I can't get this fixed I'll never buy a product from this company again because this is ridiculous.
- randomousityJan 01, 2019Luminary
No. If they're in AP mode, they aren't performing NAT. NAT is a router function, connecting two different networks (e.g., 192.168.1.0 on your LAN, and, say, 60.17.163.0 on the WAN, from your ISP). When you're running the Orbi in AP mode, everything connected to the AP is on the same IP network (maybe 172.16.1.0, provided by your ISP modem/router, for instance, for the LAN side), regardless of how anything is connected to the Orbi (wirelessly, LAN port, WAN port).
If you're changing the Orbi to AP mode, maybe try power cycling the modem/route, and the Orbi router (in AP mode) and Orbi satellite(s).
- Augustus_377Jan 02, 2019Guide
Thank you for giving me ome more info. I'll try that soon. Currently my entire family is home and i'll be killed if i try messing with the internet while they're here.
- FURRYe38Jan 02, 2019Guru - Experienced User
Understandable. My best time to do stuff like this is after everyone has gone to bed. :smileywink:
randomousity is correct as well. AP Mode disables any NAT and routing functions of the Orbi. Just works as a data traffic passthrough.
Thank you all so much for all the help. I'll try powering off all the extenders and switching to AP mode and what-not soon. I'll report back anything in a day or two when I have the time to mess with the internet.
- Augustus_377Jan 12, 2019Guide
This is ridiculous.
I've turned my Orbi back to AP mode and turned all the satellites and the Orbi router off and on and it still isnt working.
ugh.
- FURRYe38Jan 12, 2019Guru - Experienced User
Are you sure you have the ISP modem/router configured correctly?
What happens if you conenct your PC directly to the ISP Modem with out connecting to the Orbi?
- Augustus_377Jan 13, 2019Guide
No wait! It did work!
Sorry for the late response, I was busy playing Red Alert with my friends the rest of the night.
Wow, it realy was "Did you try turning it off an on?"
Thanks for all the help, you guys are the best!
- FURRYe38Jan 13, 2019Guru - Experienced User
Glad you finally got it working. Enjoy now. Hope the family will enjoy too. :smileywink:
I would do a save configuration to file on both ISP modem and Orbi.
