Augustus_377
Dec 26, 2018Guide
Can't Port Forward or Host Game Servers with Orbi
Hi, i've been searching around online for quite a while now and se a lot of people have had problems with port forwarding on orbi systems. But i haven't seen an article or forum post like with mine. ...
- Jan 03, 2019
Ok. Take your time when doing it and start with the Orbi router first. Turn off the satellites and don't worry about them until you have the Orbi router setup and tested. Ensure the configuration of the ISP modem is correct for your gaming needs. The Orbi in AP mode will only just pass thru data from the modem to your PC. It won't effect what you have set up on the modem/router while in AP mode.
Jan 02, 2019Guru - Experienced User
Understandable. My best time to do stuff like this is after everyone has gone to bed. :smileywink:
randomousity is correct as well. AP Mode disables any NAT and routing functions of the Orbi. Just works as a data traffic passthrough.
Augustus_377
Jan 03, 2019Guide
Thank you all so much for all the help. I'll try powering off all the extenders and switching to AP mode and what-not soon. I'll report back anything in a day or two when I have the time to mess with the internet.
- FURRYe38Jan 03, 2019Guru - Experienced User
- Augustus_377Jan 12, 2019Guide
This is ridiculous.
I've turned my Orbi back to AP mode and turned all the satellites and the Orbi router off and on and it still isnt working.
ugh.
- FURRYe38Jan 12, 2019Guru - Experienced User
Are you sure you have the ISP modem/router configured correctly?
What happens if you conenct your PC directly to the ISP Modem with out connecting to the Orbi?
- Augustus_377Jan 13, 2019Guide
No wait! It did work!
Sorry for the late response, I was busy playing Red Alert with my friends the rest of the night.
Wow, it realy was "Did you try turning it off an on?"
Thanks for all the help, you guys are the best!
- FURRYe38Jan 13, 2019Guru - Experienced User
Glad you finally got it working. Enjoy now. Hope the family will enjoy too. :smileywink:
I would do a save configuration to file on both ISP modem and Orbi.
