Augustus_377
Dec 26, 2018Guide
Can't Port Forward or Host Game Servers with Orbi
Hi, i've been searching around online for quite a while now and se a lot of people have had problems with port forwarding on orbi systems. But i haven't seen an article or forum post like with mine. ...
- Jan 03, 2019
Ok. Take your time when doing it and start with the Orbi router first. Turn off the satellites and don't worry about them until you have the Orbi router setup and tested. Ensure the configuration of the ISP modem is correct for your gaming needs. The Orbi in AP mode will only just pass thru data from the modem to your PC. It won't effect what you have set up on the modem/router while in AP mode.
Jan 12, 2019Guru - Experienced User
Are you sure you have the ISP modem/router configured correctly?
What happens if you conenct your PC directly to the ISP Modem with out connecting to the Orbi?
Augustus_377
Jan 13, 2019Guide
No wait! It did work!
Sorry for the late response, I was busy playing Red Alert with my friends the rest of the night.
Wow, it realy was "Did you try turning it off an on?"
Thanks for all the help, you guys are the best!
- FURRYe38Jan 13, 2019Guru - Experienced User
Glad you finally got it working. Enjoy now. Hope the family will enjoy too. :smileywink:
I would do a save configuration to file on both ISP modem and Orbi.
