skolnabber's avatar
skolnabber
can't print to HP3755 from 2 Mac laptop
I have 2 different Apple laptops. Prior to installing the Orbi RBK0 router, I could print to my HP Deskjet 3755. I can no longer print to it. Although the printer is connected to the router, the prin...
  • skolnabber's avatar
    skolnabber
    Aug 05, 2019
    As per your instructions, via the System Preferences > Print & Scan, I deleted the old printer and added the printer (it had a slightly different name) and both computers can now print. Thank you!
