pmauro
Oct 14, 2018Aspirant
Can't Print to Wired Printer from other Orbi Satellites
I have an Brother HL-3140CW laser printer conencted to an orbi satellite via USB in my office. If I am in another part of the house, I can't print to it. To get to to work, I need to go next to the s...
Oct 15, 2018Guru - Experienced User
Your printer seems to have wireless abilities:
http://support.brother.com/g/b/spec.aspx?c=us&lang=en&prod=hl3140cw_us_eu
Have you tried connecting it via wireless to the Orbi?
- pmauroOct 18, 2018AspirantYes but I was having issues (can't remember details, it was a while ago) so I went with a wired connection to try to simplify troubleshooting.
- FURRYe38Oct 18, 2018Guru - Experienced User
Be sure your PCs printer driver is correctly configured to print to the IP address the printer gets from the Orbi system. Check to see if the printer has a IP address from the router.
Connect the printer directly to the Orbi router and test printing.
- pmauroOct 22, 2018Aspirant
I have a Mac and I don't see any way to get that kind of info in OSX.
Here is the info from the printer though.
