Skipholiday
Sep 13, 2019Guide
Can't register Netgear Orbi AC3000, says serial number already registered.
My Orbi says already registed. I purchased from an individual and I need to register in my name. Bitdefender Armor also will not turn on, says 'Failed to Subscribe' try again. Firmware Version V2.3....
Skipholiday
Sep 13, 2019Guide
ask me to purchase help from gearhead. thats not good.
should be a simple solution. Why no real support?
- FURRYe38Sep 13, 2019Guru - Experienced User
Please make contact with a forum Moderator. They will help you out.
- SkipholidaySep 13, 2019Guide
here on at the support you linked?
Thanks - SkipholidaySep 13, 2019Guide
I made another post I thought it was in support. Looks like its at the same place. :-/
Thanks for the help.- SkipholidaySep 13, 2019Guide
@Blanca_O can you help?
