Schultz_
Jul 18, 2020Aspirant
Cant register Orbi router
So my wife and I bought a house and the previous owner gave us his Orbi Wifi router and all the wifi extenders. However its already registered so how do I go about unregistering it. I have internet a...
Jul 18, 2020Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button for 15 seconds then release. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard at 192.168.1.1. TBe sure to write down all important information for safe keeping later on.
- Schultz_Jul 18, 2020Aspirant
on the back of it it says its an orbi ini router rbr40 I cant tell the firmware on it, we're not fully moved in yet I'm using my wifes macbook so I have no access to ethernet cable. my isp's modem is connected to it tho.
- Schultz_Jul 19, 2020Aspirant
well I was able to change the log in pw and name of it. but its still registered is there any way i can add to to my acct?
- michaelkenwardJul 19, 2020Guru - Experienced User
What tells you this?
You don't need to register anything to use a second-hand router. Registering is for support and warranty, which don't apply.
Carry out a factory reset, get the documentation and set it up from scratch.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
