Schultz_
Jul 18, 2020Aspirant
Cant register Orbi router
So my wife and I bought a house and the previous owner gave us his Orbi Wifi router and all the wifi extenders. However its already registered so how do I go about unregistering it. I have internet a...
Schultz_
Jul 19, 2020Aspirant
well I was able to change the log in pw and name of it. but its still registered is there any way i can add to to my acct?
michaelkenward
Jul 19, 2020Guru - Experienced User
What tells you this?
You don't need to register anything to use a second-hand router. Registering is for support and warranty, which don't apply.
Carry out a factory reset, get the documentation and set it up from scratch.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
