keithjake
Apr 21, 2020Follower
Can't remember security question answers for router (RBR50)
I am trying to access my login screen of my Orbi via web browser. Unfortunately, the 2 security questions are baffling to me. I believe I know my p/w into the router, but I do not recall the ...
CrimpOn
Apr 21, 2020Guru - Experienced User
keithjake wrote:I am trying to access my login screen of my Orbi via web browser. Unfortunately, the 2 security questions are baffling to me.
I believe I know my p/w into the router, but I do not recall the username (admin doesn't work).
First, "admin" is always the user name for the Orbi web interface. (There is a "hack" that can be used to change it using telnet, but there is absolutely no way it could have been changed from the web interface or the "app".)
When three invalid attempts are made in a row, Orbi pops up that Password Recovery screen. I have used it, and it works. HOWEVER, the first time I tried to use it failed becasue (in my opinion) I had failed to set the "answers" correctly. What I did the next time was deliberately click on the "down arrow" and select each question (even the top one). Maybe this is just superstition, but after that every Password Recovery has worked correctly.
So, if your memory is correct, then"admin" and the password should work. If not, and the Password Recovery process fails, you have no other choice. "Factory Reset" and configure from scratch. This time, it might be a good idea to make a copy of the Orbi configuration. (Adtvanced Tab, Administration, Backukp Settings).
