jrcruise
Sep 30, 2017Aspirant
Can't reset router
My Orbi router and satellite were working perfectely until I tried to connect a Nook to the Orbi network. It could be a coincidence, but the router essentially stopped working at this point, and I wa...
jrcruise
Dec 14, 2017Aspirant
Are you able to access your router directly from a browser? (198.162.1.1) I was stuck just like you but was able to reset my router from the admin app. No problems since then. I’ve come to really like my Orbi system.
sos1040
Unfortunately no. I was able to get through to tech support thankfully and they are mailing me another one. My router would not respond to anything at all. I was directly connected and it would not respond or show up for me to log in.
- jrcruiseDec 14, 2017Aspirant
If your Orbi router was “frozen,” it’s not surprising you couldn’t connect directly to it. You would need to make sure that your Orbi router is connected to your ISP router and that your computer is connected to the internet via that router.
