fury88's avatar
fury88
Star
Aug 14, 2021
Can't reset security questions
Hello all,   I can't seem to reset my security questions. I've tried 3 different browsers and when I hit apply it does nothing. I've logged out and logged back in and they are the same questions I ...
  • CrimpOn's avatar
    CrimpOn
    Aug 14, 2021
    fury88 wrote:
    Ugh. Ok, thanks for the reply. So do I lose any settings if I backup and restore afterwards? Resetting is such a pain and takes the internet offline for 30 mins. Never a good time to do that in my household! đŸ€Ł
    Yes, a Factory Reset erases all settings.  It is a struggle to find a time for this that will not affect the family.
    I just reset the security questions on my Orbi.  The key step is that the new password fields must be filled in.  When I tried to change security questions without entering a new password, they did not "take."
    I did not actually change the password.  I entered the original password into both of the new password fields.  What matters is that there is something in those input fields.
