fury88
Aug 14, 2021Star
Can't reset security questions
Hello all, I can't seem to reset my security questions. I've tried 3 different browsers and when I hit apply it does nothing. I've logged out and logged back in and they are the same questions I ...
- Aug 14, 2021
fury88 wrote:
Ugh. Ok, thanks for the reply. So do I lose any settings if I backup and restore afterwards? Resetting is such a pain and takes the internet offline for 30 mins. Never a good time to do that in my household! 🤣Yes, a Factory Reset erases all settings. It is a struggle to find a time for this that will not affect the family.
I just reset the security questions on my Orbi. The key step is that the new password fields must be filled in. When I tried to change security questions without entering a new password, they did not "take."
I did not actually change the password. I entered the original password into both of the new password fields. What matters is that there is something in those input fields.
fury88
Aug 14, 2021Star
CrimpOn
Aug 14, 2021Guru - Experienced User
- fury88Aug 20, 2021StarThis works. I’m accepting your solution with the clarification that you do NOT need to reset settings. Your point of adding your old password and putting the same password in the “new password” section allowed me to change the security questions.
I think this is a bug but I would understand at least putting in your current password to validation.
Thanks for the tip!!- FURRYe38Aug 20, 2021Guru - Experienced User
Enjoy.
