Philip_shaw
Aug 18, 2021Aspirant
Can't see any devices since upgrading to V2.7.3.22 firmware on my Orbi RBR50
I recently upgraded my firmware to V2.7.3.22 and I can neither see the devices (nor satellites) on the router page, or on the Orbi App. The web page for the router has also become fairly unresponsiv...
Aug 18, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
DougB628
Aug 27, 2021Apprentice
You sure do throw out the factory reset and setup from scratch option an awful lot, acting as if that is such a simple thing to do. I understand that it can resolve some issues, but I don't think it should be necessary so often, considering how painful of a process this can be for anyone that has many smart devices in their home, and many DHCP reservations configured. For someone like me who has scripts that help me restore these things more easily, this isn't so bad. But someone who has to literally reconfigure everything manually in the admin web UI, this can take hours.
- FURRYe38Aug 27, 2021Guru - Experienced User
All that can be mitigated if users had a backup configuration saved to file. Saves time when a factory reset is needed. Factory resets are a valid troubleshooting step and i do try to avoid mentioning it until all other troubleshooting has been performed and last resort. Just like everything though, users choice. It's not "mandated". :smileywink:
