moraru
Apr 05, 2019Aspirant
Can't see my Airport Express connected by Ethernet cable used to stream music
I just set up my new Orbi Ultra Performance Whole Home Mesh WiFI System. I included a few legacy Airport Express Routers (And an Airport Extreme) All linked by Ethernet Cable in Bridge Mode. The Ai...
Apr 06, 2019Guru - Experienced User
The AEs when in bridge mode shouldn't be linked to the netowork by LAN cable. Bridge mode is wireless connected to the SSID from the Orbis wifi system. Thats the fatal flaw in the configuration.
moraru
Apr 07, 2019Aspirant
Can’t connect wirelessly to the Orbi network with the airport expresses. They’ll just say can’t find base unit...
- FURRYe38Apr 07, 2019Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings uncheck the enabled SSID broadcase for 5Ghz. Set 20/40Mhz Coexistence to 40Mhz only. Set WPA2 and AES only. See if the AE's connect to the 2.4Ghz only SSID.
