Rantaman's avatar
Rantaman
Can't see my Orbi networki
Hello, I have an Orbi RBR50 router and satellite. I've spent several hours plugging them in and synching them only to never have the Orbi wifi network show up as a network to join to get them set up. Any help would be appreciated...
  • What Firmware is currently loaded?
    Are you walking thru the setup wizard with a wired PC and web browser and inputting new SSID and PW? What are you using for an SSID name? Should be something simple and not complex.
    What wireless devices do you have?
    • Rantaman's avatar
      Rantaman
      Don't know the firmware... It was set up and working fine at our last home, we just moved... plugged it back in on the new wifi system and not seeing the Orbi network.
      Using Cox Cable Internet.
      Router = Panoramic, no viewable model #
      I'm on a new Mac and followed these set up instructions:
      https://kb.netgear.com/31017/How-do-I-set-up-my-Orbi-router-and-satellite
      Trying to set up wirelessly and followed the instructions above. The router and the satellite seem to find each other (glows blue) but then the Orbi network does not show up on my computer or iPhone... so can't set up with the app without connecting to the network...
      My SSID is Orbi29 but it doesn't show in my wireless networ list
      • Rantaman's avatar
        Rantaman
        This may be the model # of the Panoramic router CGM4140COM
        Could there be some settings in the Cox admin preventing the Orbi network from being seen?
