Alboski's avatar
Alboski
Follower
Apr 21, 2019
Cant set hard coded DNS on RBR50
With recent firmware update I can no longer set a DNS address from setup\internet setup\Domain Name Server (DNS) Address.
I have a appliance that I use to handle DNS on my local network. It currently seems that I can only set this address if I also set my IP from my ISP. I need this to work indepedantly of each other.
Has this been changed because of the new subscription security service that Netgear is offering?
1 Reply
  • FURRYe38's avatar
    If they are enabled then maybe security features are disabling custome DNS. I would factory reset the RBR and setup from scratch. This time, dont' enabled any security features. Go in and see if you can set custom DNS.
