Anabeal
Jan 24, 2017Follower
Can't set up orbi with iPad
Hello. Just got orbi 2 days ago and trying since then to set up. Router seems to work as directed. SAtellite does as well. But when I try to set up with my iPad I get a message stating that there is no reliable network available. Instructions are confusing as they say to use an Ethernet or wifi cord to hook into the router. It seems there are no Ethernet cords made for the iPad and I have no idea what a wifi cord is unless it is the normal lightening cord that I use. I don't have my MacBook Pro any longer so what am I supposed to do?
1 Reply
Sort By
- Random12Apprentice
I managed to set overthing up via wireless only. There is an Orbi app for the iPad/iPhone. Have you tried that?
You should also be able to connect to the webui to do the setup if that fails, via your ipad by going to this site:
Regards
