dstranathan
Jun 14, 2018Apprentice
Cant unblock a device
I bought a brand new Orbi CBK40 system (CBR40 router/modem combo and a RBS20 satellite).
I blocked ("paused") an iPhone X (iOS 11.4) for a couple of days on my Orbi network.
Once I unbloc...
Jun 15, 2018Guru - Experienced User
What browser are you using to manage the router?
Where did you block your phone? Under Access Controls?
If anything, a factory reset on the router and set up from scratch will help get you back up and running with your iPhone if you can't get the router configuration undone from what you set up.
- dstranathanJun 16, 2018Apprentice
Typically I use Safari 11 on an iMac (macOS 10.13.5), or Chrome 63.x (same iMac). I also use the iOS app, too (poorly designed app in my opinion - dissapointed with NETGEAR here).
I blocked it from the iOS app under the "Device List" section (a simple on/off GUI slider toggle)
- FURRYe38Jun 16, 2018Guru - Experienced User
So can you unblock them using the Mac in a web browser?
