dstranathan
Jun 14, 2018Apprentice
Cant unblock a device
I bought a brand new Orbi CBK40 system (CBR40 router/modem combo and a RBS20 satellite).
I blocked ("paused") an iPhone X (iOS 11.4) for a couple of days on my Orbi network.
Once I unbloc...
Jun 18, 2018Guru - Experienced User
You might test it again and see if the same thing happens. If it does, then lets report this to NG...
Is your devices set up for IP reservations ON the router or just using Dynamic addresses?
Whats your IP address pool set for? Default 192.168.1.2 thru .254?
dstranathan
Jun 18, 2018Apprentice
All devices are DHCP. Im using the defualt IP scope 192.168.1/24.
No Static or Reserved IPs here.
