velociti
Dec 23, 2017Tutor
Can't Update Orbi Satellite Firmware
Having some trouble updating my RBK50's firmware to 2.1.1.16. Both units are on 2.0.0.74, and the online update says that the router software is up to date, and the satellite firmware says "Service U...
- Dec 23, 2017
This was the solution. Per another thread that I found, resetting and then re-syncing the satellite into my system allowed me to "login" to the satellite and upload the latest firmware. Thanks!
aaz
Dec 23, 2017Virtuoso
If you've reset your satellite then it may be using the default admin user and password of "password"
https://kb.netgear.com/31014/How-do-I-change-my-Orbi-admin-login-password
