velociti
Dec 23, 2017Tutor
Can't Update Orbi Satellite Firmware
Having some trouble updating my RBK50's firmware to 2.1.1.16. Both units are on 2.0.0.74, and the online update says that the router software is up to date, and the satellite firmware says "Service U...
- Dec 23, 2017
This was the solution. Per another thread that I found, resetting and then re-syncing the satellite into my system allowed me to "login" to the satellite and upload the latest firmware. Thanks!
folsommarc
Dec 24, 2017Aspirant
I had the same problem recently, and after troubleshooting, realized that only 1 of my 2 satellites had updated the firmware on the last auto update. However, in the admin page, it showed that no new firmware update was available for either my satellites or the router...even though it showed different versions installed.
I had to update the firmware manually on the 1 satellite and my speed returned, which I did successfully; however, it did require me to change my router admin password first, because the satellite wasn't recognizing my current router admin password.
Once I reset the password on the router, I was then able to log into the satellite and do a manual firmware upgrade.
Hope that helps.
jcmancini
Thanx everyone. I got it to work and router and both satellites are updated.
