simonsl8er's avatar
simonsl8er
Can't Update Orbi Satellite Firmware
Hi, I'm trying to downdate the firmware on my Orbi RBR50 and RBS50 router and satellite to v2.0.1.4 but following the instructions for the satellite upgrade I get a pop up window with the below erro...
  • FURRYe38's avatar
    MIght see if you can factory reset the Satellite and just let it sync. If it comes to ready, Connect ethernet to the back of the Satellite and access with FF this time and see if it will downgrade.
    Besure you have the right version for your model.
    Unpack the .zip files as well.
