GWild
Mar 04, 2019Guide
Can't Update Orbi Satellite Firmware
RBS20 Satelitte in CK40 kit.
When I installed the system in late January, I did upgrade firmware using the ONLINE update function.
A suggestion to upgrade the satellite firmware - but is...
Mar 04, 2019Guru - Experienced User
Kind of started posting here:
GWild
Mar 04, 2019Guide
For those following this - so far no one, including the chat folks have even been able to understand I can't log into the RBS20 ...
- FURRYe38Mar 05, 2019Guru - Experienced User
If the satellite is not getting admin and PW from the CBR40 after a factory reset and setup from scratch, I would replace the CBK40 system or get it RMAd.
