kmontgom
Jun 05, 2018Follower
Can't update the new firmware to one of my satellites
I have a orbi satellite in my bedroom. the past couple nights it keeps showing a pulsing white light. i have tried to automatically and manually update the firmware to that satellite. When I try t...
EDR1
Jun 06, 2018Guide
I had that same issue early on - had my satellite to far away - but excellent idea to move the satellite closer and just hardwire right into it.
Also you can look up the IP and just enter the IP into the browser and it has a smaller satellite specific UI - which I thought had the ability to update form there as well?
Jun 06, 2018Guru - Experienced User
Yes you can directly connect to
the satellite and connect to it's IP address and use its web page to update FW there as well.
