fatpearl
Jun 21, 2019Aspirant
Can't upgrade from Orbi RBR/RBS50 Firmware 1.3.0.26
How to I properly go from 1.3.0.26 to 2.3.1.60 (current version)? I can't seem to update my firmware from v 1.3.0.26. downloading 2.2.1.212 causes an error message "Please select the correct file c...
- Jun 22, 2019
FYI, to get from v1.x to v2x on any Orbi system, please download v2.0.0.74 FW files for RBS and RBR. Apply the RBS first, then RBR. Then you can upgrade to the most current version via v212 on the RBR. You can go directly to v60 on the RBS first. Then applly on the RBR lastly.
fatpearl wrote:How to I properly go from 1.3.0.26 to 2.3.1.60 (current version)? I can't seem to update my firmware from v 1.3.0.26. downloading 2.2.1.212 causes an error message "Please select the correct file configuration." Earlier versions will download but I get an error message when trying to install, telling me the file I've selected is out of date.
CrimpOn
Jun 21, 2019Guru - Experienced User
In my opinion, Netgear's documentation does not explain the process very well. The easiest path is to use a computer that is "wired" to the Orbi.
Step 1. Download the firmware files for versions "212" and "60" for both satellite and router:
http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V2.2.1.212.zip (for the router)
http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V2.2.1.212.zip (for the satellite)
and
http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V2.3.1.60.zip (for the router)
http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V2.3.1.60.zip (for the satellite)
Step 2. "Extract" the "img" files from each zip file.
Step 3. Connect via web browser to each satellite (if you have more than one), select Firmware Update, browse to the location of the "212" img file, and upload it.
Step 4. Connect via web browser to the router, select the Advanced Tab, Administration, Firmware Update, and click on the "Manual" tab. Brose to the 212 "img" file for the router, and upload it.
(There is probably a "reset" about now to get the satellite(s) and router activated on "212".)
Step 5. Now that the satellite(s) and router are successfully on version 212, repeat the process with the latest version. Start with the satellite(s) and finish with the router.
Step 6. Perform a "factory reset" on the router (paperclip, etc.) and set it up from scratch.
These steps are explained (probably better) in a lot of posts. It is a CHORE. But, when finished results in the Orbi at the most current release with a "clean" setup.
- fatpearlJun 21, 2019Aspirant
The problem is that when I try to manually update the firmware from 1.3.0.26 to "212," I get all the way to selecting (via the 'Upload Update File' window) the file for the satellite firmware update to upload ('RBS50-V2.2.1.212.img' file within the zip file downloaded, as per instructions), I get an error message that says 'Please select correct configuration file.' and an "OK" button to click. I click "OK" since it's the only option, and I'm right back to the 'Locate and select the update file on your device.' on the original 'Upload Update File" window.
I'm direct-wired, followed all of the instructions, but get stuck at the point I"m supposed to select the 212 firmware update img file for the satellite.
- CrimpOnJun 21, 2019Guru - Experienced User
Sorry if I am missing something, but the "img" file has to be extracted from the zip file. Orbi is looking for a file with the extension "img", not "zip".
I know. The update is downloaded to my mac as a zip file, which I have to open to extract the needed img file.
