fatpearl
Jun 21, 2019Aspirant
Can't upgrade from Orbi RBR/RBS50 Firmware 1.3.0.26
How to I properly go from 1.3.0.26 to 2.3.1.60 (current version)? I can't seem to update my firmware from v 1.3.0.26. downloading 2.2.1.212 causes an error message "Please select the correct file c...
- Jun 22, 2019
FYI, to get from v1.x to v2x on any Orbi system, please download v2.0.0.74 FW files for RBS and RBR. Apply the RBS first, then RBR. Then you can upgrade to the most current version via v212 on the RBR. You can go directly to v60 on the RBS first. Then applly on the RBR lastly.
fatpearl wrote:How to I properly go from 1.3.0.26 to 2.3.1.60 (current version)? I can't seem to update my firmware from v 1.3.0.26. downloading 2.2.1.212 causes an error message "Please select the correct file configuration." Earlier versions will download but I get an error message when trying to install, telling me the file I've selected is out of date.
Jun 22, 2019Guru - Experienced User
