Gummo
Jan 25, 2019Guide
Can't upgrade my firmware (to V2.2.1.20)
Trying to upgrade firmware for RBK50 (AC3000) kit - router and satelite - from original V1.8.0.6 to the latest V2.2.1.20. Auto update reports that V1.8.0.6 is the latest version and when Manual upg...
- Jan 25, 2019To complete the firmware upgrade I had to first do several of the firmwares before the current. Pick one that is a few above your version and see if it takes it. If not go one above your version. At some point one of them allowed me to go to the latest so you won’t have to do everyone between your current version and the latest. Fustrating process but it got me to current.
Jan 26, 2019Guru - Experienced User
First download v2.0.0.74 and v210 for both router and satellite(s). While you have the satellites connected, send the v.74 file to the satellites first, then send the file to the router. Once both of those are updated and back online, send the v210 FW to the satellites, then send the FW to the router. Should be updated and working then. A reboot of the entire system should be done after completing the FW upgrade process.
Gummo wrote:
Trying to upgrade firmware for RBK50 (AC3000) kit - router and satelite - from original V1.8.0.6 to the latest V2.2.1.20. Auto update reports that V1.8.0.6 is the latest version and when Manual upgrade is actioned the V2.2.1.20.img file (from the downloaded .zip) is not recognised! Any help will be greatly appreciated. Thanks in advance. Z
