yanivf
Aug 17, 2019Apprentice
Can't VPN using Windows client - WARNING: No server certificate verification method has been enabled
I'm trying to connect to the VPN server using OpenVPN but I get the error "WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info."....
CrimpOn
Aug 19, 2019Guru - Experienced User
I, also, have problems with the Windows VPN. The first time, I neglected to print off the "instructions" that pop up when the link is displayed (not the BIG link that says "Windows", but the tiny link under that). So, I had not created the NETGEAR-VPN network link that is required. I also created problems by renaming some files but not renaming the link to the files that is inside the opn setup file.
