yanivf
Aug 17, 2019Apprentice
Can't VPN using Windows client - WARNING: No server certificate verification method has been enabled
I'm trying to connect to the VPN server using OpenVPN but I get the error "WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info."....
petieg1
Aug 19, 2019Aspirant
Add remote-cert-tls server to config file.
Remove error in the client at least.
yanivf
Aug 19, 2019Apprentice
Thank you petieg1 ,
I have done this step at #3 as you can see from my original response. It does pass the original error however fails in the next one. I'm thinking I might have some firewall i need to punch through. Will continue doing some more investigations.
- CrimpOnAug 19, 2019Guru - Experienced User
ho, yes. Windows Firewall will definitely block the VPN. Have to "add another program" to the Firewall rules.
I did this with OpenVPN and also with Tunxten. (trying different VPN clients)
