Totallydubbed
Jul 06, 2023Aspirant
Capped download speeds on BT Full Fibre 900 (RBR50)
Hi all, I've spent a large amount of time trying to decipher my issue but have hit a brick wall. I have recently upgraded to BT's full Fibre 900. My RBR50 is connected to a singular RBS40V. No mat...
- Jul 08, 2023
So, an update: I called BT and as I thought, they said, they can't help me with the Netgear product, however, they can confirm that no routers are capped in any way by themselves or Openreach.
On a side note, the black and white Wi-Fi discs bt BT are identical technically speaking, just that the black one is older, while the white one is EE branded (partnership) and is the one that's sold by BT to anyone who wants it. I was curious to know if the BT system would solve my issues, that's why.
Anyway, back on subject, tech support oddly said that if a node is connected (at least on their mesh system), it can half the throughput; it didn't make much sense to me as my tests were being done at the router, not at the node.
Nonetheless, I manually disconnected the RBS40V and re-ran tests; and suddenly I was getting 900/100 at the router with the Netgear Orbi!
I then re-added the node back to the system (which should have been a simple procedure, but instead required me to do two factory resets - why, Netgear!?), and then the router was still reporting 900/100.
Now, I'm not sure what the solution was: resets, removal of node and re-adding, maybe even server locations having different speed readings on separate days, but regardless I'm pleased to say that it's magically solved.
So I can confirm that at the router (wired), you can achieve 900/100 through the Netgear Orbi system (the original RBR50 + RBS40V).
A question, however, if anyone knows: what is the maximum speed the node is capable of when connected over ethernet? Thus, Moden -> WAN port to Netgear Orbi router (RBR50) -> Wireless to Node (signal = Good, 5G signal reported) -> Node to PC connected via Ethernet.
At the moment via my PC that's now connected over ethernet to the node (RBS40V) upstairs, I'm seeing a max of 450mbps. Is this due to the throughout of 866mbps being halved (as per BT's instructions), or due to it being capped at 450mbps over wireless? Would there be a means of getting the max 900mbps via the node with another mesh system? If so, what do I need to look for?
Totallydubbed
Did you just copy and paste different information and completely ignore what was mentioned in the OP?
Jul 06, 2023Guru - Experienced User
I copy and paste as I see fit. Ya I read. Posted as I saw fit. Please give feedback.
- TotallydubbedJul 06, 2023Aspirant
Great, so the feedback is: an utterly pointless reply.
-Connected via ethernet, the same which achieves 900mpbs via the SH2
-RBR50 connected directly, as mentioned, with speed tests again as mentioned
-There is no modem at play (either it's just the SH2 or just the RBR50). I tried in AP mode just for the sake of it, and as you'll see (clearly not!), I already did the recommended (ie disable Wi-Fi/AP mode selected not router mode)
-Who talked about wireless?
- FURRYe38Jul 06, 2023Guru - Experienced User
Probably an incompatibility with the RBR and your ISP HW.
Id' try the RBR at a different location, say friend or family to see if the problem follows with a different ISP HW.
Don't have anyone local with Full Fibre 900; indeed, seems like there is an issue with Netgear not working correctly with BT's services, which is leading me to believe I should buy a new mesh system and get rid of the Netgear one.
