twnewsom
Dec 09, 2021Aspirant
Captive Portal causing Dropout
Hello, Generally, I am very happy with the RBR20... that said, I have discovered a problem with the system and I don't know how to resolve it. The Guest Network is currently disabled (though it was ...
CrimpOn
Dec 09, 2021Guru - Experienced User
It does seem that a number of configuration changes cause the Orbi router to go through a lengthy process of restarting things (although what things is not clear to me and other configuration changes do not have the same effect). For example, turning Guest WiFi on or off seems to result in that spinning circle while forwarding a port does not. No doubt the engineers thought "to be safe", we need to restart some activities in certain circumstances.
It is not surprising that a VPN connection would get disrupted. It would be interesting to see a screen shot of that message (with any personal information erased). If maintaining that VPN connection is critical, I would not mess with the router unless I am unable to restart the VPN session.
The other issues are most likely not related to 'orbilogin.com' and devices are not being asked to log in to the Orbi router.
twnewsom
Is there a way to prove it? Because so far what I can see in the admin console are that the sattelites are connected and the connection quality is good. But, I can proveably show that turning off the malfunctioning sattelite allows devices that were connected to it, to connect to another node and connect to the internet.
Regarding the captive portal, I don't have one configured that I know of. However, even on computers that don't have a VPN, when they have this issues and I try to connect to say google.com to search up a speed test (an example I have tried)... google will report that the certificate cannot be validated and that it appears someone is trying to intercept the connection. Looking at the certificate shows orbilogin.net as the certificate domain.
Unfortunately, I don't have pictures of it right now. But, I am hoping someone else has experienced it and disabled the orbilogin.net captive portal somehow.
Since I can show that it is happening on my computers (and also that it happened on a firestick when I loaded the web browser) I am reasonably confident that the connection problems are due to the captive portal and disabling it will resolve my issues.
- CrimpOnDec 09, 2021Guru - Experienced User
Part of the confusion is my fault. I had just discussed Orbi's implementation of OpenVPN with someone and made an incorrect assumption that your VPN was a remote laptop connecting to the Orbi LAN over OpenVPN. I see now that VPN refers to a laptop connected to the LAN using VPN to connect to the internet.
On the topic of captive portal, this is a true mystery. The term is often referring to how WiFi access is granted at hotels, coffee shops, airports, etc.: https://en.wikipedia.org/wiki/Captive_portal This is not something that can be enabled (or disabled) on an Orbi WiFi.
The issue with orbilogin.net has existed for more than two years. A long time ago, Netgear purchased SSL certificates for a bunch of URL's (routerlogin.com, routerlogin.net, orbilogin.com, orbilogin.net and maybe a couple more). In August of 2019, that SSL certificate expired and was not renewed. Nobody knows if (a) Netgear did not renew the certificate because somebody forgot or the person who should have was out on Covid, or (b) the certificate authority decided that having thousands of routers all over the world claiming to be "Netgear" was absurd. Anyway, later in 2019 Netgear put a self-signed certificate in their router firmware. Modern browsers go bezerk when they see a self-signed certificate WARNING - - UNSAFE. All of my browsers do that, so I look in the small print for the option to "go there anyway", and the browser remembers from then on that I know what I'm doing.
Honestly, I cannot remember how people solved this problem in the past. Perhaps they did a Factory Reset on their Orbi and reconfigured it.
Sorry to have made a hash of this.
- twnewsomDec 09, 2021Aspirant
lol No worries. :-) I have been dealing with it for a long time, so I am just now getting around to reaching out to the community to try and solve it. I am guessing that, even though they have a self signed certificate, the expected behavior is not that an attempt to load google.com would route someone to orbilogin.net (or any other domain). It's almost as if the routing table has been corrupted such that all requests to any domain result in an attempt to redirect to orbilogin.net. Restarting the router device (sattelite or main router) does fix it for a while. However, it inevitably comes back.
Wish I could flash my own firmware on these devices and fix it myself. I might just have to switch to freemesh or some other open source mesh router so that I can get some stability.
