wonderbliss
Dec 10, 2023Guide
Captive Portal for Orbi RB50
How can I set up a Captive Portal for my Orbi RB50 router?
Dec 10, 2023Guru - Experienced User
Something thats not supported on Orbi home systems.
CrimpOn
The most recent Orbi Pro systems support a Captive Portal for the Guest WiFi logon. See page 108 of the user manual:
https://www.downloads.netgear.com/files/GDC/SXK80/Orbi_Pro_WiFi_6_UM_EN.pdf
Moving to the Orbi Pro is a "fork lift upgrade" because none of the existing Orbi 50 series product is compatible with the Pro line. The SXK80 products are not inexpensive.
