Bkhatton1's avatar
Bkhatton1
Follower
Jun 05, 2019
Cat6 distance between my orbi router and original router
I have the RBR40 system. Is there a max distance you can place you wired cat6 orbi router from your original WiFi router? I know max run on cat 6 is 328 feet. But does it matter to the routers? I’m not talking about the satellites.
1 Reply
  • schumaku's avatar
    schumaku
    Yes, it's an Ethernet link - so anything up to this length must remain workable.
