anschmid
Feb 03, 2017Apprentice
CAUTION: Orbi's Wifi Guest Network does not really isolate guests from main network
I was just playing around around with the Guest Network in Orbi and made a rather disturbing discovery that guest clients don't seem to be separated totally from the main network, in fact can access ...
st_shaw
Nov 22, 2017Master
CliffP wrote:
I have Orbi on latest firmware and set in Router mode, not AP mode.
I connect to the guest network on my iPhone and then use the Fing app (https://www.fing.io/) and can see every single device--i.e. it's useless as a guest network. :(
You can see devices with Fing. So what? If you try to ping or connect to any devices from a client connected to the guest WiFi, you will find that you cannot.
Boatguy54
Dec 20, 2017Guide
Not true. I'm able to connect to any number of devices that use Bonjour. Other posts show similar flaws in the security.
And "so what"? The first step of hacking into a system is know what targets are availble. The product says it hides guest users from each other. So what is that it doesn't do that.
- Mr-WednesdayJan 18, 2018Tutor
I can confirm that this is still an issue with firmware version V2.1.2.18.
Signed into the guest network and using Fing I can see ALL devices on my regular home network. In the Guest Network settings, "Allow guests to see each other and access my local network" is unchecked.
- MarinJimJan 25, 2018Tutor
To clarify, am I correct that, as of January 2018, the Guest network still has the various shortcomings described above, but only when operating in AP Mode? And that, when using the Orbi in "router mode" (i.e., as your main router), the Guest network operates as it should (isolating main network resources, including making them invisible to guests on the Guest network)? Thanks for the clarification.
- Mr-WednesdayJan 25, 2018Tutor
No, the issue still exists when in Router mode too.
That's a shame. After all this time, I'd assumed that Netgear would have been able to fix this and totally isolate the Guest network, as they've done on the last several Netgear routers I've used.
It's a deal breaker for me. A secure, isolated Guest network is critical. I was just doing my final research before running out to Costco to buy the RBK50 with two satellites to set up this weekend. Now I'll have to reassess.
To be fair, the devices in my guest network sit in the same IP range as my regular network. However, I would still expect them not to be able to see the devices in my regular network.
Or maybe I'm doing it wrong?
- appierroJan 30, 2018Apprentice
Will a Netgear engineer pick this issue up? This is an issue that is across many threads and affects many users and seems to not have been resolved for some time. Guest Network is essentially rendered useless.
- DarrenMJan 31, 2018Sr. NETGEAR Moderator
Our support team would like to troubleshoot this issue with you if you would like to work with them please send me a PM with your name, email, and phone number.
DarrenM
- schumakuJan 31, 2018Guru - Experienced User
wrote:Our support team would like to troubleshoot this issue with you...
This is a design failure. Nothing the customer support can fix.
Business and advanced home users expect correct isolation of the work and the guest network. VLANs are not introduced since yesterday, and are not rocket science. And again for the records, this is nothing new with Orbi for Business, with Orbi, ... the issue exists as long Netgear does offer this highly questionable "design" on earlier routers, Nighthawks inclusive.
Very sad. - MarinJimJan 31, 2018Tutor
DarrenM -- thanks for the post and for the interest in resolving this. If you read back through the posts, you will see what the issue is, so I am not sure I could add to it by directly communicating with you via PM or phone. If I am mistaken, however, and if you would like to contact me by PM, please PM me and I will respond with my phone number and email address to discuss the problem with you. I'd like to see this issue resolved in a firmware update. As it is now, I (and others) see this as a critical flaw that must be corrected.
- JoeM845Jan 31, 2018Luminary
Any help is welcome. I opened a support case on this in March, shortly after I bought the unit. I have been informed from time to time that engineering is working on it. I did not return the RBK50 on that assurance.
- BIG9MMFeb 01, 2018Apprentice
1. Unfortunately, I'm experiencing the same thing with the guest network seeing everything on my local network. I understand if you uncheck the option about the guest network not accessing each other they are supposed to not have access, but still is there a way if you're logged in to the guest network be able to ping devices on the local network? If so that's a security vulnerability.
2. My girl brings her law office laptop home and it is connected to the local network, I don't want the guest network to be able to have any access to her work computer or really even to see it... I can put in front of the ORBI my other router Asus rt-ac88u which I just need a little help understanding how to set it up that way and I greatly appreciate if you guys can explain if there's a workaround if I implement my Asus rt-ac88u in front of the ORBI.
- AspenthedonMar 23, 2018AspirantI think when it's in router mode it does NOT properly segment network I will be checking because I am in process of setting up iot devices and this would really skew me
- NaderAMay 11, 2018NETGEAR Employee Retired
All,
Thank you for your choosing Orbi Pro and your loyalty with Netgear. I appreciate all of your feedback that helps us making Orbi Pro an even better product for your business. I personally read all of your feedback and comments and take them very seriously, especially in cases like this.
Please note that we have identified the issue and have rectified it with a FW update that you can download and update your Orbi Pro units.
This FW update can be found below.
Download Orbi Pro Firmware 2.1.4.8 with Client isolation
Orbi Pro Product Management
- RocketSquirrelMay 11, 2018Luminary
NaderA wrote:
All,
This is the Orbi “non” Pro forum. Would love to see an isolation solution for the home products.
- JeremyinsfMay 11, 2018Apprentice
Yeah, I appreciate that you state that you read them all and take them seriously, but I agree you misunderstand. Isolation is supposed to be an option on non-Pro and that's what this thread is about. There is a checkbox in our settings, and it's worthless.
I have devices that I do want to totally isolate from my PC and files, and non-Pro is supposed to do this - but it's another bug that has been unresolved.
MY guess is that you fixed the bug for the Pro because many have a business requirement to isolate traffic, and you probably don't want to get sued.
If you really are reading all these messages, perhaps you can put a new, general thread up explaining to everyone on these forums that you understand how upset your user base is about the overall lack of quality in your firmware (and QA), and what you plan to do to fix it, and what the timeline is.
- JoeM845May 14, 2018Luminary
NaderA wrote:
All,
I don't understand why the FW link takes you to a page on salesforce.com.
I, too, would appreciate it if Netgear addressed the problem for the non "pro" Orbis
- rhester72May 15, 2018Virtuoso
100% agree. Security is *NOT* a business perk. It's a market requirement, period, and if you don't grasp that, your competitors do.
- BIG9MMJun 26, 2018ApprenticeI posted it a while back that I was dissatisfied about guest network able to access the local network but I just want to clarify with this new patch, Orbi firmware update v2.1.4.16 does it fix the issue now? Any clarification on this would be helpful and beneficial for future customers.
- JoeM845Jul 16, 2018Luminary
BIG9MM wrote:
I posted it a while back that I was dissatisfied about guest network able to access the local network but I just want to clarify with this new patch, Orbi firmware update v2.1.4.16 does it fix the issue now? ...I updated to FW 2.1.4.16 today by clicking on the update message on the RBR50 main Web GUI page and then electing to install all automatically. It proceded and completed. The sattelite took a few extra minutes to complete, but it eventually sinced up with no manual intervention.
It seems to be working more-or-less as well as it was prior to the fw upgrade:
1) The Prosafe Plus utility will no longer brieach the guest network wall to let me reconfigure switches (note: Also upgraded to 2.7.2)..
2) My IP scanner tool still shows devices on the main network -- both IP and MAC addresses)
3) A number of devices are missing from the connected devices displays where they used to appear. Sattelite shows 1 device (> zero). I would exoect to see the remaining devices split between the 2 ORBIs.
- dragunovAug 16, 2018Aspirant
Hello,
I've just updated to v2.1.4.16 firmware on my home Orbi system. I've been recommended by cyber security professionals that I isolate smart devices in my home on their own separate network. The responses here seem to indicate that Orbi is not taking this seriously for non-pro users - can anyone confirm if they have made the necessary changes to ensure our security in this latest firmware?
Thank you.
- Mr-WednesdayAug 16, 2018Tutor
You just installed the latest version. Can't you confirm for us?
- User00Nov 25, 2018Star
As of 11/25/18 - the problem still exists. Although I'm in AP mode - realizing that it's not actually separating the two networks is enough for me to return this device.
- schumakuNov 25, 2018Guru - Experienced User
As you see form reading this thread, Netgear does not intend to change this for the consumer class Orbi system.
- User00Nov 27, 2018Star
FWIW, I opened a ticket with Netgear explaining the issue and asking if this was by design or a bug. They asked me to send them my config and they will put it in their test environment to confirm. To me, if that would allow one engineer to see the problem in action and then be able to fix it - i'll keep the setup.
Of course, now as I'm in the process of changing the SSIDs and passwords of the config - I ran into another weird bug - where the satellite only seems to sync the base password, but not the WiFi settings unless I perform a factory reset.
So for me, fixing these two issues (and maybe adding an option to remotely reboot the satellite without having to upload a firmware) - then you have a decently solid product.
- User00Dec 02, 2018Star
So response from Netgear support (had to be escalated) was that because the SSIDs are indeed on the same network - the broadcast NMAP/Fing traffic cannot be prevented. However, because they are blocked from actually making any connections to those devices then that's sufficient for Guest isolation. If you are able to make a connection to any device, then they'll investigate further.
So while, it's not necessarily a deal breaker for some - I wish they would mention this on the product page without having the users discover it on their own.
