anschmid
Feb 03, 2017Apprentice
CAUTION: Orbi's Wifi Guest Network does not really isolate guests from main network
I was just playing around around with the Guest Network in Orbi and made a rather disturbing discovery that guest clients don't seem to be separated totally from the main network, in fact can access ...
DarrenM
Feb 01, 2018Sr. NETGEAR Moderator
I have raised this concern to engineering about the guest network. BIG9MM if you want to use another router in front of the orbi system you would just need to set orbi in ap mode.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
DarrenM
schumaku
Feb 01, 2018Guru - Experienced User
Can Orbi and Orbit Pro in AP mode support a proper VLAN set-up with multiple SSIDs mapped accordingly, with both the wired and the wireless backhaul?
Considering Insight 4 is supposed to support these devices soon: How will Orbi and Orbi Pro APs be integrated with a capable Insight/Smart Managed Pro VLAN switches and the low cost WAC505/510 access point VLAN infrastructure offering correct network isolation then please?
What routers does Netgear suggest for such environments - considering all Orbi, Orbi Pro and Nighthawk are suffering from these problems - and still (after years and years of customer requests!!!) not support industry standard tagged VLAN?
Insight does make it possible to set-up, manage and expand such an environment with ease. Netgear has everything required to fulfill this very basic requirement - except of routers.
Deploying a different router without VLAN-SSID mapping on Orbi does not solve the issue. The KB entry is ok for flat networks only and does in my opinion not apply to an environment requiring proper isolation.
Netgear has all design and engineering capabilities for switching and wireless access in home, SOHO, and SMB - including a nice Insight management system. Just the Nighthawk and Orbi/Orbi Pro are still stuck on the first home router design limitations from 25+ years when Netgear introduced the first ZyNOS based router to the market. Worth noting: That router had capable IPsec VPN capabilities for a VPN server and a VPN client. And it had the ability to add WAN-LAN firewall filtering rules. Capabilities silently lost since. And the community is full with requests for these features. It's just that the people in charge apparently don't care about real world requirements.
Just like the broken (and impossible to achieve) pure Layer 2 guest network isolation. Should Netgear be interested in a product line manager - I'm available.
