anschmid
Feb 03, 2017Apprentice
CAUTION: Orbi's Wifi Guest Network does not really isolate guests from main network
I was just playing around around with the Guest Network in Orbi and made a rather disturbing discovery that guest clients don't seem to be separated totally from the main network, in fact can access ...
Mar 23, 2018Guru - Experienced User
The first wave to be released are only for the RBR50 and RBS50, which is used in the RBK50 and RBK53 (Costco) kits.
New beta FW avaialble. Get it while its hot of the press:
Might fix this issue...
Vandergraff
Mar 24, 2018Apprentice
What do you mean 'Might fix this issue...'
Nothing in release notes suggests it would?
