anschmid
Feb 03, 2017Apprentice
CAUTION: Orbi's Wifi Guest Network does not really isolate guests from main network
I was just playing around around with the Guest Network in Orbi and made a rather disturbing discovery that guest clients don't seem to be separated totally from the main network, in fact can access ...
Mister-Mike
Aug 27, 2018Aspirant
OK - I am hoping for some (possible) help here... I am very concerned about this. I have around a dozen or so small mortgage offices (only a couple of users at each), where I have the Orbi RBR50 plus satellite installed. in all cases, the networks are IPV4 only, and IPV6 is disabled. All of the units have the absolute latest firmware to-date (2.1.4.16). At each location, I have the private network on subnet 192.168.0.X, and on the Orbi, the network is in ROUTER MODE on subnet 10.0.0.X. I have discovered that, even with the option DISABLED in the guest network settings, that ANYONE who connects to the guest network can easily and readily access ANY of my servers/resources on the 192.168.0.X subnet! I was pretty shocked. I managed to connect to the guest network, and easily not only PING one of the servers, but was able to RDP onto the server, as well as access the shared data volume.
This is completely unacceptable - and this is at all 12 locations. Again - with only 2 or 3 people on-site, I saw no reason to go beyond the RBR50 + Satellite units for these tiny offices. And I assumed that correctly having the guest network set-up would keep access to the wired 192.168.0.X network secure. Again - IPV4 ONLY, in ROUTER mode. Is there a fix here? I am already running firmware 2.1.4.16. The thought of having to replace all of these, because of a glitch with Netgear, is ridiculous. I loved these so much, that I also bought this for my own home, and for friends' homes. One note - I was promised over the phone when speaking to Netgear for general product info, that the guest network would be isolated! Ugh..... now what?
If anyone has any ideas or advice, it would be so very much appreciated... more than you know. Thank you very much in advance for any help you can give...
- FURRYe38Aug 27, 2018Guru - Experienced User
I see there was mention of this issue being resolved in the PRO version. Not sure if this has populated to the Home version. I presume you are using the PRO version? Or Home? It's not recommended to use Home products in a business setting. Things test to lead to products not working as well for the Business environment. Business envrionments need more than Home class products for safter and secure operations. You may need to look into better business solutions for your needs if your using a Home class system. If your concerned about this, you'll need to disable the Guest Network feature on your systems.
- Mister-MikeAug 27, 2018Aspirant
Hello! Well, I wish I was advised to buy the Pro. The offices are small, only a couple of users each.... and I was ready to purchase whatever was recommended. No one mentioned a Pro system. So now I will need to look into upgrading... however I can't believe there isn't an answer to this. Because - regardless, this is also completely unacceptable in ANY home environment. An isolated guest network is just that - an isolated guest network, whether in a home or wherever. I am not opposed to buying Pro versions, but I need some type of stopgap/workaround in the meantime if possible...
I would disable the Guest Network. If you just got the Orbis, you should check into returning them after looking into the PRO version...
Something to ask NG about and see.
- st_shawAug 27, 2018Master
If I understand what you wrote correctly, you have Orbi in Router mode behind another router, with the 192.168.0.x subnet on the WAN side of Orbi.
If so, the behavior you report is not a glitch with NETGEAR. The behavior is as expected, and is due to the way you have Orbi setup.
Guest isolation pretains only to the LAN side of Orbi and does not affect traffic heading to the WAN side of Orbi. The PRO would behave no differently. Also, Orbi's guest isolation only pertains to wireless clients, not wired machines.
If you want to maintain two separate networks, then you need a router that supports multiple subnets and IP-based firewall rules to control traffic between subnets. If your current router doesn't support this, you could buy a cheap router that does and run the Orbi in Access Point mode behind that.
Thank you for that insight/explanation...
So, if I am understanding you correctly... then the following scenario WOULD work, or? As follows:
- A cable modem coming into the building, in Bridge Mode / Pass-Thru mode.
- The modem connected to the WAN port of the ORBI (yellow "Internet" port)
- a small gigabit switch connected to one of the ports in the back of the ORBI (1 thru 4 - any port)
- the switch, connecting to several PC's in the home via Cat5e/Cat6 Ethernet
- The ORBI in ROUTER mode, provided all IP assignments / DHCP assignments
- Then, create a GUEST network in the wireless settings.
In this scenario, with only the ORBI providing all routing, and the only thing behind the ORBI is a cable modem in Bridge Mode, providing zero routing... then anything on the LAN wired through a small switch, then connected to one of the ports on the back of the ORBI. In this scenario, would the guest network be able to "see/interact with" the wired devices?
If this is the case, I can easily implement this type of setup (these are VERY small places - just a couple users, one single room etc.).
Thank you again for the clarification!
Your isolation requirements aren't clear to me. But, yes, in the scenario you described, any wireless client connecting to the Orbi's guest SSID would be blocked from interacting with the rest of the Orbi LAN--both wired clients and wireless clients connected to the Orbi non-guest SSID. This assumes guest isolation is enabled on Orbi (and working as designed.)
