anschmid
Feb 03, 2017Apprentice
CAUTION: Orbi's Wifi Guest Network does not really isolate guests from main network
I was just playing around around with the Guest Network in Orbi and made a rather disturbing discovery that guest clients don't seem to be separated totally from the main network, in fact can access ...
ThisIsAwkward
Jan 31, 2019Aspirant
Just got off the phone with a support engineer. He claims since a guest network is a different SSID key they are different networks? I am skeptical since nodes on my guest network are assigned IP's that I have defined on my LAN (10.0.0.2 - 200). I was hoping to have a guest network in the default IP range (192.168...). Has anyone gotten this configured successfully?
schumaku
Jan 31, 2019Guru - Experienced User
Netgear does deploy some L2 isolation for the standard vs. the guest network on these consumer devices. All systems are run from the same DHCP in the same subnet. The isolation can be cobsidered "good enough" for consumer applications. On Orbi Pro a few enhancements have been implemented, ebahxibg the isolation. Still it's not intended to serve dedicated VLAN and dedicated subnetworks and DHCP pools.
Not amused Netgear support engineers are not able to explain this in a few words.
