anschmid
Feb 03, 2017Apprentice
CAUTION: Orbi's Wifi Guest Network does not really isolate guests from main network
I was just playing around around with the Guest Network in Orbi and made a rather disturbing discovery that guest clients don't seem to be separated totally from the main network, in fact can access ...
schumaku
Mar 07, 2019Guru - Experienced User
Vahik wrote:
Activated the guest mode and uncheck the "Allow guests to see each other and access my local network". Now on guest wifi, can not open the routers login page, but all connected devices to the main wifi are visible by NetAnalyzer app on android.
Yes - however you won't be able to establish e.g. TCP or UDP connections for example beteen the different networks. This was explained in this thread before several times. Scroll back to about Messge #57 - there is even a reply from johngm on the subject. https://community.netgear.com/t5/Orbi/CAUTION-Orbi-s-Wifi-Guest-Network-does-not-really-isolate-guests/m-p/1540059/highlight/true#M26848 Netgear does not intend to enhance things towrds a full VLAN-like isolation on the consumer routers (Nighthawk, Orbi). Only the Orbi Pro systems will get (or have received already) some enhancements.
schumaku
All the guest WLAN, the standard WLAN and the LAN are sharing the same L2 infrastructure including the very same TCP/IP subnetwork and DHCP server with DHCP pool and more. With the isolation feature for the guest network enabled (that's all there is implemented!), the individual guests can't communicate with other devices on the guest network or with devices on the standard (W)LAN. In no way this is providing a complete L2 isolation bottom up.
