Mountainview1
Mar 16, 2019Follower
CBK 40 Cable System (Replacing RBR50 and sat) set up Question Please
Thanks so much all: to eliminate ongoing conflicts, update gear and streamline equipment, I’m replacing my Spectrum cable modem and it’s router along with my Orbi traditional RBR 50 System being used ...
Mar 16, 2019Guru - Experienced User
Please post here for anything CBK40 related:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
If you open up the Orbi APP while connected to the RBR system. there is a remove button that you can select and this should remove that system from the account and app. Then I would go thru and add the new system to your account.
