jim_lebbad
Mar 09, 2022Aspirant
CBK 752 Blinking white Upstream
The Upstream light is blinking on my Orbi CBK 752. How do i correct that?
Mar 09, 2022Guru - Experienced User
do you have a copy of the cable connections page?
That'll show the upstream/downstream data.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
- jim_lebbadMar 09, 2022Aspirant
Thank you so much.
