isaiah1112
Dec 02, 2019Tutor
CBK40 6Mbps Upload on Xfinity Gigabit
I recently aquired a new Orbi CBK40 Router/Modem combo to replace my CM1100 modem and a Nighthawk Router. I have Xfinity gigabit service and on a normal day I see 400+Mbps download and 40Mbps upload...
Dec 03, 2019Guru - Experienced User
So what happens if you factory reset the CBR40, setup from scratch, don't enable speedtest, access controls or traffic meter or change the MTU value on the CBR40. Just wire connect a PC and speed test with Ooklas installable speed test app.
isaiah1112
Dec 06, 2019Tutor
I believe that is what I did upon the initial factory reset. However, I will attempt to run another test this weekend of exactly that to see what happens and will post an update as soon as I have the resutls.
