blakejnd
Aug 05, 2018Aspirant
CBK40 and Comcast/XFINITY issues
I just purchased a new CBK40. The installation went smoothly. I unplugged the XFinity modem I was renting and used the Netgear app which was a breeze. I should have known it was a little too e...
Pfredd
Aug 06, 2018Guide
My ORBI cabke modem works great on Comcast/Xfinity. I am getting better than advertised speeds, acording to Speedtest.net
You might try going to xfinity.com/setup. You will need your comcast onlin login credentials. Once inputed, it queries your ORBI for serial number, model, etc. and then you are good to go.
