ozeanfrau
Feb 14, 2019Aspirant
CBK40 and SDR-C75300 (ipoilis app) problems
Replaced my cable modem and router with this nice setup and have great WI-FI in the whole house but I can't get my security cameras to work online and with the ipolis app. Everything worked fine befo...
ozeanfrau
Thanks FURRYe38,
Firmware Version V2.2.1.210_1.0.8
ISP is CableOne
10 of these Samsung SDC-9441BC 1080p Full HD Accessory Camera (all wired)
Wired to the router, always been wired so I don't think the wi-fi or channels are a problem.
Old modem was a Netgear CM400 and router was a Netgear R6220.
Internet speed is good. I get pretty much the same speed on wi-fi as wired on my PC.
I really need to know why wisenet takes me to my router settings and maybe something about the app settings if possible.
Feb 15, 2019Guru - Experienced User
Possibly that the Samsung software is pointing to the router incorrectly rather then it's cameras.
The CBR40 is a Gateway modem/router so everything is combined into one unit, unlike before when you had a separate modem and router.
I'm also on C1. However I don't have or use Samsung cameras. I presume it has to be something in the cameras software getting confused by point at the router side of the modem and it's routers web page at 192.168.1.1.
Are you using 192.168.1.1 for the routers web page on the CBR40? You could try changing this to use something different and see if this changes anything. I always using 192.168.0.1.
This will be kind of a sticky one. Something Samsung should be able to answer as why there software is directing to the modem/routers web page in a gateway setting when before you had separated modem and router configuration and worked then.
