Eberhart
Sep 27, 2018Aspirant
CBK40 Network Down Solid Red Light
On Cox cable internet.
My CBK40 base station router/modem keeps going off line. 3 times in the last month.
I can't find anything describing what it means if there is a solid red light. Ma...
Eberhart
Oct 05, 2018Aspirant
I think red. I tried to replace all of the cords with new cable-company provided cords with no change.
Going back over the paperwork that came with the device I think it is really overheating. It never got hot to the touch, but that would explain why the internet & network went off line at the same time. When the light is solid red, the entire device is dead. After 6 or so hours I would manually restart the device and it would boot up normally. Suggesting that it had time to cool off?
This started happening with more frequency so I finally gave Netgear a call. The Netgear rep I talked to suggested it was because it was plugged in to a surge protector, but I'm not sure that mattered. The device was well-venilated and is plugged in to a qualitiy surge protector.
I ended up pressing Netgear to swap the device, so we will see how that works out.
Oct 05, 2018Guru - Experienced User
Ok, let us know how it goes. The unit will be warm. Mine did. However I normally keep a laptop fan cooler under any router I have online 24/7. Helps keep router cool. Something you might look into for long term cooling and use.
