Bach1804
Jul 23, 2020Aspirant
CBK40 Orbi no longer listed as supported with Spectrum
I purchased my CBR40 in April for use with Spectrum. At the time the logo was on the box. When it arrived, the logo wasn't there but I figured maybe the packaging hadn't updated? I set it up and it w...
- Jul 25, 2020Resolved. Charter came out and determined it was a signal issue with their lines. Nothing to do with the equipment. They were great, fixed it and everything is working just as it should! Finally!
vkdelta
Jul 24, 2020NETGEAR Employee Retired
It is listed as supported device up to 400 Mbps
https://www.spectrum.net/support/internet/compliant-modems-charter-network/
- Bach1804Jul 25, 2020AspirantResolved. Charter came out and determined it was a signal issue with their lines. Nothing to do with the equipment. They were great, fixed it and everything is working just as it should! Finally!
- FURRYe38Jul 25, 2020Guru - Experienced User
Good to hear. Glad it was the ISP.
Enjoy. :smileywink:
