Rudy69
Nov 14, 2019Tutor
CBK40 slow upload speeds
Just connected my Orbi, and my upload speeds went from 35-40Mbps to6. Any ideas?
Nov 14, 2019Guru - Experienced User
we'd need more info to help. Its like saying my car used to drive 100mph but now it only goes 20mph. Why? Details are needed.
1. who's your isp?
2. What speeds do you pay for (upload and download)?
3. How are you testing speeds? With the built in app? With your phone? A hardwired pc? (hardwired pc is best)
4. What website are you testing with? Sometimes the servers they test with aren't reliable, although those speeds should be fine
5. Do you have a screen snip of your modem connections page from the cbk40? (get both upload and download connections)
6. What have you done to try to fix it? reboot/reset/remove coax splitters-other coax line issues)
7. When you say "just connected" are you saying you just installed it? What were you using before?
Rudy69
Nov 14, 2019Tutor
Hello Txs for the response. My ISP is Xfinity and I have the 1000mps download speed. I use the Orbi app or Speedtest for testing speeds. To fix it I tried restarting the devices. Didn’t change coax cable as it is the same one that was hooked to the gateway from Xfinity that I had. And yes I just installed it and was using Xfinity equipment
- Rudy69Nov 14, 2019TutorThese were my upload speeds before
- plemansNov 15, 2019Guru - Experienced User
please post a screen snip of your modem connections page.
also try using a computer hardwired to the modem and try the speedtest app.
you didn't put if you've tried anything to fix the problem.
I get that you didn't try replacing the adapers. But if you were using a docsis 3.1 modem from your provider and the cbk40 is only a docsis 3.0 device, its a little more sensative to line interfernce. Try removing any splitters, amplifiers ,attenuators, kinked lines, or extended runs.
Another thing is the CBK40 is only rated to 500mbps per comcast. it can handle up to 900mbps but comcast only certifies it for 500mbps. having a gig connection through comcast with the CBK40 is just paying for speeds that its not rated to.
