Wes213
Feb 19, 2023Aspirant
Cbk750 can't connect to anything rockstar.
I have a cbk750 and it has worked just awesome with everything I have thrown at it with the exception of Rockstar games related content, I am unable to log in to Rockstar social club on any device goi...
- Feb 20, 2023
đ
Feb 19, 2023Guru - Experienced User
Something to contact the game mfr or Microsoft about.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Wes213
Restarting is the first thing I try everytime as I'm not new to this and have restarted the router/modem as described many times before reaching out for help.
Since it is an all in one unit I can't exactly follow your method to the letter but have preformed the situations equivalent, I also have no idea how contacting Microsoft or the console manufacturer would help considering it works fine connected to my mobile hotspot or someone else's modem.
While I appreciate the attempt to help nothing listed here is relevant or something I haven't tried.
- FURRYe38Feb 19, 2023Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
Then walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System?- Wes213Feb 19, 2023AspirantI have factory reset a few times and had no luck even with a wired connection but I'll give it another go with the listed IP range and report back as soon as I can.
- Wes213Feb 19, 2023AspirantWell I gave that a go and while my IP addresses are significantly higher the same problem still persist.
This one is really stumping me and having had computers my entire life that is really saying something. LoL- FURRYe38Feb 20, 2023Guru - Experienced User
I'd be curious if you put your gaming device into the CBRs DMZ long enough to see if this helped any.
Remove the device after testing.If you get good results, may mean that there could be a need for some port forward configurations...something to ask the game mfr about and see...
